Washing Machines Logo
Posted on Feb 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There's a foamy soap left in my washing machine after the laundry is done. We've established that I'm NOT putting in too much soap; it just isn't rinsing properly. The repair guy says it is draining fine, then yesterday the machine pumped out more than five gallons of water into my apartment. Changed the timer and there don't seem to be more floods. Still soap in the washer, though.
  • Anonymous Feb 23, 2009
    My clothes are still filled with soap even after the rinse cycle is finished.
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 14, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5036756
Points
35540
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Where do I put the liquid soap for the wash
Lichid soap for automatic washing machines is not indicated, since foam is produced and can be a nuisance when coming out from every seal and can perturb the function of some sensor.However, if needed, can be poured on the powder tray (100 ml) for about 5 kg of laundry or directly inside machine, on top of laundries is better. Don't forget to close the door afterwards.
2answers
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
I have a Frigidaire ATF7000ES1 model. It's about 5 years old. Today when I did the laundry, it stopped by itself. I turned the knob, nothing happened. After awhile, the power was back on. I set it...
could be many things... possibly the starter capacitor is gone (google what this is if interested), but lets start simple... If the machine isn't getting water, this will make it stop. Check the taps are on, hoses hocked up, test hot and cold cycles, even pull out soap draw while ur at it and give it a good clean as soap always builds up anyway. But i am getting a feeling that ur machine is getting water otherwise you would have mentioned it. The other thing is to check that water is getting out ok. Is the pump blocked? Give it a clean anyway because everything you put into your machine goes through the pump, so it works hard. The good thing about these exercises is that you'll start to get to know ur machine. A good friend of mine once told me some advice when trouble shooting... "get to know how it works, and then you might find why its broken". And then check the switch on the door. The trip switch on the door prevents someone putting the arm in machine while its spinning at 1400 rpm. Hopefully by now you've opened up the machine to marvel at its inner workings... Check the obvious that wires seem connected and hose clumps are in their correct position. Lets turn our attention to the motor. Is there a belt? Is the belt on? Can u turn the drum around manually? (Do this with power off which you should have well and truly done by now). If these are all yes, lets check the motor on spin cycle - which we probably could have done before pulling case off. If it isn't spinning at all, check to see if there is a fuse in the cpu board (this is the brains of machine). If fuse blown, this could be due to motor gone or starter capacitor gone. let us know how you get on
2answers
My GE Profile washing machine leaves soap suds in the bottom and on the clothes. I use Cheer liquid detergent. My husband says it is because of placing too heavy of items, such as towels, in the machine....
Use ONLY the recommended amount of detergent per the label on the detergent.
Pour detergent in the tub first then start the water,then add the laundry.
Do not overload the machine.
Use a bathroom scale to weigh 12-15 pounds of laundry and no more.
Big tubs invite more laundry.
Don't be fooled by a big tub.
1helpful
Where do i put the laundry detergent?
Top left is a drawer. Be sure you put it in the soap dispensing department. Put HE stuff in there. Do not put too much. The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Any more than this and you will get errors and headaches.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Everytime we do laundry, we have a horrible smell in the washing machine. We have tried bleach and hot water but no success. Any other ideas?
Be sure your using HE Laundry det. only use the recommended amount on the bottle, I use the liquid, the less the better, I use the least amount.....To much soap left in clothes can cause mildew and stinky smell, also I recommend using a fabric softner, it helps to remove the soap....and smells good....also use a good washer cleaner, I use Affresh, they come in tablets, go to www.affresh.com and put in you zipcode to find where you can purchase it in you area......make sure after a load is finished that it doesn't sit in the tub with the lid down for long, removing the laundry promptly will also help with stinky laundry........also, leave the lid or door open for a couple of days to air it out after cleaning.....use the Affresh at least once a month.......hope this helps you
What holes
Open the drawer at the top left of the front of your machine: you will see 3 compartments: right is prewash, middle is for softener, left is for wash. WATCH OUT- these machines do not need as much washing powder as the american models-putting too much soap could damage your machine and lenghthen the cycles.... I use half of what I used in my previous american washer.... do not be surprised either by the spinning cycle: before going full blown into spinning the machine has sensors that perit autobalancing of the laundry. You must not load laundry above 3/4 of the diameter of the drum.
After wash is done there is still soap on the laundry help!
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
8. re-try.
2helpful
2answers
Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
Top Washing Machines Experts
john h
