Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
I bought a dc500 secondhand, overall a good bit of kit, mine recently blew the fuse inside after I changed the battery it ran very fast and then failed, so I stripped it down and replaced the fuse, it blew again immediately, I identified that the supply to the motor was 20v where it sould be around 12 volts.
I tracked it down to a faulty mosfet component on the battery regulator board, desoldered it and bought new one from rs cost about a quid, relatively easy to do if your familiar with a soldering iron.
hope this helps
Very helpful. My DC to DC board was not regulating the voltage to 12V and kept blowing fuses. Since I wasn't sure which one was bad I ordered both the STPS1545CT rectifier and the IRF5305PBF MOSFET . The component costs were around $1 each (US). I changed the 1545CT first and it did NOT resolve the issue. Next I changed the IRF5305PBF rectifier and confirmed it resolved the issue by connecting a Dewalt XRP 18V battery and testing the output to the motor. The component replacement process requires a soldering iron, solder sucker, and component dykes. I reinstalled the DC-DC circuit board in the unit, reassembled it and I'm back in business.
This unit operates on 12-18v dc and 120v ac. Inside the unit are two converter circuit boards. The motor is DC so the 120 v has be converter using the AC to DC circuit board. If you use one of three different volt batteries (12, 14.4, or 18v) then the DC converter circuit board drops the voltage to 12-12.5 volts. Typically, when one of these circuit boards goes bad it will cause a small in-line 15 amp fuse to trip. You can replace the fuse but it will blow again untill you replace the circuit board. Usually one power source will work and the other will not. If the battery works (DC-DC circuit board - ok) but the A/C power (AC-DC c.b.) trips the fuse, then this is what you need to change. You can buy and factory fuse (soldered tips and covered in black shrink wrap) or buy a simple universal fit one that will be easily to replace once you have corrected the problem.
