SOURCE: pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
SOURCE: i have a 47cc pocket rocket and there is no spark
first, if all connections are good, try replacing the spark plug, if still no good, check if coil gap to rotor is .020". if the is good, you will need to replace the ignition coil.
