Your best bet would be to do a soft reset of the ipod:
- Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
- Press
and hold the Menu and Center (Select) buttons simultaneously until the
Apple logo appears, about 6 to 8 seconds. You may need to repeat this
step.
Tip: If you are having difficulty resetting your
iPod, set it on a flat surface. Make sure the finger pressing the
Select button is not touching any part of the click wheel. Also make
sure that you are pressing the Menu button toward the outside of the
click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power
adapter and plug the power adapter into an electrical outlet, or
connect iPod to your computer. Make sure the computer is turned on and
isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)
- Press
and hold the Play/Pause and Menu buttons simultaneously until the
Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat
this step.
If this does not work then you may have to re-format the ipod in itunes. If you click on the ipod in itunes you should see a RESTORE option on the main page.
