check for spark by holding a screw driver in the plug wire and holding it about 1/4'' from metal while someone pulls the rope for you a bad coil will cause a no start
Hold down the time or month/date buttons, then press either of the '<< or >>' (by CD controls) to move the time, or month/date. To change the year hold down both time and month/date buttons together to adjusting the year using the '<< or >>' buttons.
If you're reading the programming instructions in order, keep going :-) I have no clue what SLT hold mode has to do with music on hold or background music, but when you get to 111-BGM-Music On Hold source, you can set it to external and you're in business.
Hello, you can make the display larger by pressing and holding down the Control button (usually marked Ctrl ) and pressing the '+' button. Make it smaller by holding Ctrl and pressing down the minus button ( - ) Alternatively, you can alter the resolution by right-clicking on the desktop, selecting 'properties' , then 'settings' and then altering the adjusting the 'screen resolution' ; less resolution, bigger the font. Regards, nicam49
To turn off predictive text, just go to the menu of the phone and select the message, then you select the option for message, then you will see the predictive option settings there you can turn it off.
That is how to turn off predictive text on your phone.
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode. If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
All those lights etc on the right side of your dash
are not tied to anything
You don't have to change anything
or do anything. Oil,Cabin Filter etc
THEY ARE JUST GADGETS
Status does cycle
You press Reset & hold
When it says to hold, you
quickly press & hold Reset again
You can just forget all that
Doesn't do anything
You don't sit in your car &
call it up with the status button
& watch it anyway.
Brake Fluid-every 2 years --Flush/All Vehicles
Spark Plugs -- every 3 years,not over 60,000 miles
Fuel Filter --every 3 years
Air Filter --every 3 years
Cabin Filter --every 3 years
Trans & Power Steering--3 years
not over 30,000 miles--EVER on any vehicle
Press and hold the circle button down, after a few seconds it will flash 'beep on/off', dont stop holding it down, it will then cycle to 'units', press +/- to change between metric and imperial, then press the = button to store. If you keep holding it down you can set the reference pont (where the measurement is taken from, the back, middle or front edge of the machine) add an offset (add take away from the displayed dimension), and you can also reset the machine.
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to
toggle through the selections to set T1. T2 (for another time zone) is
up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
