Question about Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002
Airmatic system how do you know it is bad
    Champion:
    Scholar:
  • 227 Answers
General level..... it will tell you
Technical level - Gets pretty technical to figure out what went wrong. You need a scantool cabable of that year models suspension system, good manuals, and years of experience helps ALLOT!
Posted on Oct 31, 2013
SOURCE:
The airmatic system may have froze up
CHECK AIR SUSPENTION PUMP OR CHECK STRUT FOR LEAK
Jan 21, 2014 | Mercedes S-class S500
Mercedes s430 airmatic, car too low
my problem is airmatic stop car too low
Sep 28, 2012 | 2000 Mercedes-Benz S-Class
My suspension (airmatic ML 350-2006 ) is always failing and showing the "visit workshop" message. please what is the solution?
i have a s350 from 2004 and i have a guestion.
Is it possible to replace an airmatic suspension by a normal suspension?
If it is possible are there any suggestions about which one?
Mar 21, 2011 | 2007 Mercedes-Benz ML350
Can not get car to rise or lower car sits on wheels
possibly faulty airmatic pump for suspension, first open boot and boot floor mat then have look on spare wheel, you can see your tools extra fuses and fuse diagram on it, take fuse diagram and read it you can find what's the fuse no and fuse box where is the airmatic pump fuse and relay is, check fuse and relay first, if the fuse blown replace same fuse for that now you know where are the extra fuses, get one from that, start engine is the car not rise up operate the switch above the radio still not working either faulty airmatic pump or control unit, you can check pump yourself turn steering fully left, remove clips from bulkhead inside wheel arch only need to remove front section then have a good look inside you can see airmatic pump is hanging on chassis rail under the right head light, have a good look wires on pump if it dried and broken that's the fault, only solution either repair pump or replace new pump. if not the faulty pump you have to get diagnose the car by experience technician, is this information helped you?
Oct 25, 2010 | 2000 Mercedes-Benz S-Class
2001 s500 airmatic problem car air compressor stays on long and the car is very high
check the relay for the airmatic compressor it is on the passenger side in the engine compartment right next to the hood hinge. pull the cover off and its the 3rd relay back from the front. the relay might be sticking closed but have it checked before it causes the compressor to burn itself out
Oct 21, 2010 | 2000 Mercedes-Benz S-Class
I have the car to low error message on the display the bags are bottomed out and wont raise up. its on a e 500 2003
The suspension has a leak somewhere and/or the airmatic compressor has stopped working properly. You need either the Mercedes star diagnosis system (SDS) in order to access the suspension control module to tell it to raise the vehilce or you can try to trick it by jacking up the car so it thinks it's sitting at the correct ride height. But as long as the display reads a warning it won''t allow the airmatic compressor to run.
Oct 12, 2010 | Mercedes-Benz 500-Class Cars & Trucks
S500 2003 4 matic the airmatic light comes on and
souds like air bags in ridding systen have a leak
Aug 21, 2010 | 2001 Mercedes-Benz S-Class
Car sat for 5 days not driven, now get "Stop car too low" error
Sounds like you may have a leak in the airmatic suspension struts on the rear. These govern the height of the car in different modes. Not an immediate problem unless you are loosing a visible amount of fluid but it will only get worse.
To check if you have airmatic you will have buttons just behind the gear lever which can be used to put the car in to a stiffer, lower mode or to raise it for rough ground
Jun 29, 2009 | 2003 Mercedes-Benz E-Class
Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002 Logo
101 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
