HEWLETT-PACKARD HP G62 Notebook Logo
ahmed Posted on Mar 05, 2013
G 62 touchpad color repair
Color of touch pad changed by fingers touch in 2 years. my laptop is in silver color and i want to get back the same color and need help please
Pari K
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Dec 14, 2013
Pari K
Contributor
Level 1:
New Friend:
Answers
38
Questions
Helped
5084
Points
49
Change the entire palmrest Any paint isnt worth doing Believe me i have tried
Touch pad does not work
Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
4helpful
2answers
Asus Laptop Touchpad trouble shooting
Step 1:
Touchpad Not Working in Laptop b> Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
3helpful
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
hope this helps
Key pad is not working
hope this helps
Touch pad not working
hope this helps
1helpful
Touch pad not functioning
Hi jon bernardo...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Compaq 730us touch pad not responding
Hi
To fix an unresponsive touchpad on your laptop/desktop XP Home, XPPro:
Reactivate it by using the Function key on the keyboard and the Fn key.
Touch pad scroll gestures very intermittent.works then doesnt
Hi tommymul6...
Try this solution to your problem
2answers
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
4helpful
3answers
How do i turn off zoom function of synaptics touch pad Hp laptop
Are you talking about the two finger zoom by spreading your fingers apart on the touchpad to zoom out or pinching them together to zoom back in?
This works for Dell touch pads so below where it says ‘Dell touchpad’ it probably says HP touchpad?
· Goto your control panel
· Click on ‘Mouse’
· Click on the ‘Dell touchpad’ tab
· On the resultant popup screen, double click on the main touch pad region
· Click on the ‘gestures’ setting
· Uncheck the zoom
Good luck…Chris
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
