Question about LG LDF8812 Stainless Steel Built-in Dishwasher
How to clean mesh filter on lg dishwasher lds5811ww
SOURCE:
MNTECH
  • 1543 Answers
SOURCE: parts breakdown for a LG dishwasher LDS5811WW
Yes. If you disconnect the water line from the dishwasher you will see a screen inside the inlet to the water valve. This should be a Fix-Ya for your dishwasher. Thanks for the question.
Posted on Dec 13, 2008
  • 50 Answers
SOURCE: dishwasher
The LE code indicates motor failure (or intermittent problem with motor). Based on what Ive read their support sucks, so sory to be bearer of bad news...
Posted on Jan 05, 2009
stradeteox
  • 88 Answers
SOURCE: I have a LG dishwasher
No filter in these units. It is possible that sand has gotten into the sump assembly and is not allowing the vario motor to properly switch between the upper and lower spray nozzles.
Posted on Jan 18, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: water leaking from dishwasher lg model lds5811ww
The drain line is clean. Have you checked to make sure the the rest of the drain is clear all the way down to the main drain?. Also check the pump to make sure that it is working properly, it might be pumping water in, but it may not be wanting to pump the water out
Posted on Feb 11, 2009
rickead1
  • 1998 Answers
SOURCE: We have an LG lds5811ww dishwasher with IE error
check for voltage at the water valve when it should be filling Try disconnecting the Water Valve outlet from the DishWasher and run the output into a bucket if all is well with the valve then remove the door panel and inspect the wires near the bottom of the door. the wires get buried in the tar like insulation causing the wires to break as the door is opened and closed.That tar like substance is one of the worst things they could of ever put into that machine causes the wires to break apart adn become brittle
Posted on Apr 30, 2010
Trouble removing the macerator from a lg lds5811ww for cleaning. Want to make certain no foreign objects stopping blade.
After removing lower rack and then the spray arm (pulling directly up and out), remove the (approximately) 12 silver screws from around the guard. Lift out to gain access to the lowest sump area.
Watch out for broken glass down there, it is sometimes almost invisible... and sharp!
May 18, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Apr 30, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Water leaking from dishwasher lg model lds5811ww
Feb 11, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Lg dishwashers
The LG dishwashers have a perminant mesh filter just below the bottom spray arm.
The filter can be removed by removing the spray arm by pulling straight up, then removing 10 phillips screws. Whenever you remove the filter, inspect for debris beneath the filter (including hard to see broken glass.)
Jan 03, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Parts breakdown for a LG dishwasher LDS5811WW
Dec 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
I have a LG dishwasher model # LDS5811WW is there a filter of some sort at the water intake? My water has be known to have sand in it . The dishes are not all washing some are some aren't.
Dishwasher
Nov 01, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG dishwasher does not seem to clean items on lower rack
Can you tell me if the problem was fixed by the original posters?
The multi-level wash direction feature uses a check valve just below the mesh filter asembaly and is driven by a vario motor underneath the check valve. By removing the mesh filter (10 screws and the lower spray arm) you expose the check valve. It is very close to the pump that empties the water through the drain hose.
High probability problems: -The Check Valve could be jamed/stuck. -Also, the Vario Motor could have failed
Please respond back with the findings on this problem. Thanks!
Sep 29, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
178 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
