Apex Digital AT2702 27" TV Logo
Posted on Mar 05, 2013
Trying to remove parental lock on Apex Digital AT 2702s 27'' tv with a RCA universal remote
1helpful
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Need code for AT2704S Apex DIGITAL
Your Apex TV is locked by someway. To unlock it,
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
If you want more details, click this link. Pull up older posts there.
3helpful
2answers
Apex codes
Hello
You are seeking codes with RCA systemlink-3 remote control to Apex TV. Unfortunately, there is no setup codes for Apex Tv with this remote control. It is very difficult to gat a remote control that has setup codes for Apex Tv.
Comcast On demand custom-3 universal remote control has codes for Apex.
Codes are :
0748, 0765, 0767
OK.
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
T.V. LOCKED
Please view this FixYa Tip which outlines the procedure for removing the parental lock when the screen is locked on the Apex TV.
Thanks for using FixYa.
My Apex television is locked
Have 27' Apex tv, model #2702S. A red key is in the lower left corner of a blue screen. No direct or remote response. Have tried unplugging it.
parental control is on, need original remote to turn off parental control, something like push F key down and something else at the same time, I need original remote, cannot find one to buy
good luck with your problem
2helpful
2answers
My TV is completly locked up
You need a APEX remote to unlock the parental controls. You and go to there web site to get the ording info and he preocedure to unlock the tv. www.apexdigitalinc.com
APEX 32" FLAT PF3220 PARENTAL CONTROL
You can try but, I bet the original remote is needed for this operation.
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
