SOURCE: DVD Playback Error
here is the link for the manual if you need it - ask again if you don't find what you need. http://audiovox.com/manuals/owners/VM951... Hope this helps :)
SOURCE: jensen uv8 no pic and very noisy when loading
No, it is not your laser, the jensens have a little trick to making them work, after you put the toggle switch in, you need to place it in the on position, turn it off and back on 5 times in 5 seconds, one flip per second, then the unit will start to play video, after you turn it on for the fith time. you should end in the on position. jensen does this so that you can not just ground the wire to get it to work.
SOURCE: Wont load or eject
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
