Keurig Elite B40 Coffee Maker Logo
Posted on Mar 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Keurig Elite 40 (B40) beeps continuously when I turn it on.
It won't brew or heat. I believe that water has been transferred from the reservoir to the brewing chamber. But it just beeps and illuminates the power, auto off and heating lights and sounds a very loud, piercing beep continuously. Cannot find info online or in Keurig documentation. Help!
Dayton Computer
Level 3:
  • Master 1,640 Answers
  • Posted on Jan 31, 2014
Dayton Computer
Master
Level 3:
Answers
1640
Questions
0
Helped
819005
Points
6396
Heating element may be damaged...return for exchange asap
3 Related Answers
espressonist
espressonist
  • 1711 Answers
  • Posted on Aug 15, 2010
SOURCE: My Keurig Elite B40 will only brew one cup of
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Anonymous
  • 2299 Answers
  • Posted on Oct 27, 2010
SOURCE: Problem with the Keurig Elite
Keurig is having a big problem with this. When you turn it on, pick up the reservoir and place it back down. What you are hearing is the unit trying to pull the water through and it won't. It will try for a minute and then shut itself off. So power on, lift and lower water unit and it should be good. CALL KEURIG and tell them about the problem. If enough of us call then maybe they will do something.
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
  • Posted on Dec 22, 2010
SOURCE: keurig b40 won't brew. took reservoir off,
erwrwr33434
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Why it's not heating up
Try starting from scratch, I have included a link to the manual that will help you through that. If that does not solve the problem you probably will need to get it serviced.
Keurig Elite B40 Getting Started
How to descale keurig elite 40 coffee maker with vinigar
Unfortunately you will need to use vinegar. The acetic acid in vinegar is strong enough to clean most brewing machines.
Use distilled white vinegar.
Keurig b40 pump out of sync
PLugged exit port tube. Manual Page 18
Keurig B40 problems
Clogged ports see page 18 Manual for assistance.
2helpful
1helpful
All of a sudden my mom's Keuring B40 won't make a full cup of coffee.
Mine started to do that about a month ago. I would have to brew multiple "cups" just to fill one coffee cup. I ran several cycles of the largest cup, without any K-cups, to clean out the small metal spout. After about 3 hot-water cycles, it worked fine. I do this periodically, as I don't use the Keurig daily, so some of the residue builds up between uses.
Only 1/2 cup or less of coffee brewing. Water is going back into the reservoir at brewing tim.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
