On device manager there is no errors, laptop only works wired, when i try and put wireless capabilities on it takes me to files and when i try and troubleshoot it says please turn wireless capabilities on detailed information says turn on wireless capability failed
SOURCE: fujitsu siemens laptop
press the fn key and the f2 key, the fn key should be at the bottom of your keyboard, normally on the far left side.
SOURCE: Medion Akoya Multimedia notebook - wireless capability
I believe on the medion you have there may be a switch on the front or side to turn on the wireless. That or FN key and F1.
press the fn key then i think its the f5 key but which ever f# it is it has kinda like wavy lines on it read the instruction manual too it does tellyou
SOURCE: cant turn on wireless capability on fujitsu siemens amilo li2727
The issue is that it isn't turned on by default in the bios. Here is a link to a how guide to set this up.
SOURCE: 'turn on wireless capability' Acer Aspire 2930
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. GO TO EXIT AND SAVE..
