Cord connected light is illuminated. Motor will not run. there is no "click" when switch is depressed. Have removed vinyl side strips from cannister but cannot find means of separating cannister halves to gain access to switch compartment.
Well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Need switch for 3500 epic
