GE PSS25SGN Side by Side Refrigerator Logo
Posted on Feb 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vegetable and fruit crisper drawers freezing foods
Ge Profile stainless steel, side-by-side with built in water and ice dispenser is freezing foods in the vegetable and fruit crisper drawers. I have taken out the two drawers and noticed ice formed on the fridge in the left corner where the second to last drawer is located. What is the problem? We are having a very similar problem that I noticed starting a couple of days ago with the vegetable bin starting to freeze everything in it. Also the digital display reads in the low 30's for a fridge temp. Even after trying to reset it, it goes back up a couple of degrees but then after a few hours it goes right back down to 30 degrees and freezes the vegetables again. I have a PSS25SGNA Side by Side that's probably about 6 yrs old so no more warranty unfortunately. I was hoping that it was something I could order online and install ourselves, but it sounds like it's probably not going to be.
Thanks for the info, I tried to find help on GE's site, but they didn't have anything about this problem there.
Anonymous
Level 3:
  • GE Master 3,361 Answers
  • Posted on Feb 21, 2009
Anonymous
GE Master
Level 3:
Answers
3361
Questions
Helped
1029077
Points
10654
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
3 Related Answers
Anonymous
  • Posted on Feb 11, 2009
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Dec 17, 2009
SOURCE: vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Anonymous
  • Posted on Jan 07, 2010
SOURCE: vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Can you adjust the temperature on the water dispenser?
The water for the dispenser comes from a reservoir in the fresh food section behind the crisper drawers. So the only way to make the water colder is to turn down the temperature in the fresh food side of your refrigerator. The water dispenser is designed to dispense chilled water, not ice water. hope this helps.
2helpful
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
I have french door with freezer on the bottom refrigerator in the GE profile line. I have the internal ice cube maker. My ice cubes melt into one big block of ice. I lowered the thermostat to -5 but that...
check ur temperaTure in the freezer make sure it is 5 degrees fahrenheit or lower if it is u might need to see if ur ice maker tray has a crack i it to where when the water goes in to be frozen it runs out a crack and if all this is good check to see when the ice maker fills up its just not running over
The water is leaking from the Ice dispenser and the food is thawing
Seems like the freezer is not getting cold enough. If the ice maker was leaking the water would freeze. It would not cause the food to thaw.
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
3helpful
2answers
Good Lucak!
3helpful
5answers
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Top Refrigerators Experts
vince
Johnny 1000
