What model Uniden 5.8GHz phone/answering machine? Exactly what does it do after four rings? Does it just drop the call or continue to ring? Is the answering machine turned on?
There should be a switch towards the bottom on the right hand side
Setting ring time switch
The ring time/toll saver switch allows you to set the
number of rings the caller hears before the answering
system plays your outgoing message. You can set the
switch to answer af ter two rings or af ter four rings.
Once the greeting has star ted, you can stop it when
you pick up the call at the handset or base.
In the TS (Toll Saver) position, the answering system
picks up af ter two rings if you have new messages,
and af ter four rings if there is none. This way, if you
call long distance to check your messages, you can
hang up af ter the third ring to avoid billing charges.
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
Press Menu/Select.
Select the Ans. Setup menu, and then the Ring Time submenu.
Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
Press Menu/Select. You will hear a confirmation tone.
Press Menu/Select.
