Hey,
here is the user manual for ex-s100
http://exilim.casio.com/resource/pdf/manuals/EX-S100.pdf
if you can't open the user manual you will need a pdf reader
http://www.adobe.com/products/reader/
Note that the Casio link before may be slow, if it doesn't open in few minutes right click on the link and select save as.
Let me know if you need anything else.
Thanks,
Ekse
The lens mechanism could be jammed and cause a failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre., being an expensive camera
get estimate before you decide. It will be good to have it checked at the Casio service as you do not have to run around for spares.
