No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Samsung CLP-310 / CLP315 (Black). 68grams black toner
(CMY) 48grams
color toner
Yes there is a reset chip. Check e-bay for $55.00 you get the chip, 4 colors refill. Shipping is $19 and some.
I use only one chip to refill 4 toner (CMYK) cartridge
Click here for details: http://www.hoanglinh.vn/default.asp?id=6
We have solution for samsung clp-315 by which you can refill as many time as you want without any problem. No chip required when you refll your cartridge . It is permanent solutions.
I also have Zero cost solution for samsung -scx-4300, ml-2240,ML 2245, ml 1640. clp 315/ 315, It is working permenently. Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
msn: [email protected]
call : +91 9825523201
www.chipresetters.com
hello?
How do you refill the CLP-315 cartidge? Where should I drill the hole?
E
i have refiled clp-315 needed software for toner
How much toner are you supposed to fill in each of the color cartridges as well as black cartridge, I mean how many grams ? If anyone knows pl let me know.
where to buy refill toner for the clp 315? if i buy the reset chip, i still can't find online site that sells this toner in bulk. Or is this toner the same as the clp 300?
How do you refile clp-315 needed software for toner/
what about continually topping up the cartidges before the printer starts to blink?
So that the chip is never activated?
G
