Fails to send signal to external monitor, PC itself won't shut down even with on/off button, fan running noisy. Would like to shut down so I can reseat the memory module but cannot turn off the machine.
SOURCE: Dell laptop Latitude c 810 BIOS revision A12
you got the wrong type of memory installed open the memory bay and remove move it from socket 1
SOURCE: Dell Inspiron 1000 will not boot up.
Greetings,
The symptoms you described are normally common motherboard failure signs.
Try removing the ram and hard drive from the computer and then try booting the computer.
SOURCE: How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
SOURCE: dell latitude d820. press power button. no
This may be a really stupid question, but you could have overlooked it... Are you sure the power cable is attached to the laptop correctly? It seems like it's just short of power.
SOURCE: Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
