Karcher 2500 PSI Pressure Washer Logo
Anonymous Posted on Mar 04, 2013
I have a Karcher model G 2401 HB and need to know what type of oil to use in pump ?
I would like to put my pressure washer back together but i need to know what type of oil to use in the pressure pump !
  • Anonymous Mar 11, 2013
    oil to be used is nonfoaming nondetegent 15w40
acehead
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 107 Answers
  • Posted on Oct 18, 2013
acehead
Expert
Level 2:
New Friend:
Cheetah:
Answers
107
Questions
0
Helped
102269
Points
113
I fixed mine works good too, watch my video step by step i put it on youtube
http://www.youtube.com/watch?v=UFXSLOBL0Mg
3 Related Answers
Martin Grech
  • 94 Answers
  • Posted on May 22, 2009
SOURCE: Can't fine where to put pump oil in
Dear glenoaks06,
I handled various Karcher washers, but the 2500 I never came across it. Just the same I will give you a few hints and maybe the solution for the problem. When the oil is milkey this means it has water in it. This means that there are faulty seals for sure. Now in many Power Washers the compartment where the oil is located is filled with oil prior to assembling the head unit that contains the pistons. So you have to take apart the the complete head change all seals( HP seals, LP seals and OIL seals). There are pumps that take multi-grade oil(15/50) and others 90 grade oil. If your pump is fan cooled, it probably takes 15/50 oil. Now one of the main biggest problem of water in oil is Faulty and Scratched PISTONS.
So when you have the pump apart....check condition of pistons. It is useless to change seals if pistons are damaged.
Now one thing regarding your problem, is that you have to put together the head with the pump upside down, so that you can fill the compartment (where the pistons are pushed by the swash plate), with OIL, before you put back the complete head with good pistons,springs,seals, valves...etc..etc. These few hints are relevant to quite a number of Karcher washers.
Regards,
Fulltech.
Anonymous
  • 6 Answers
  • Posted on Sep 08, 2009
SOURCE: Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Anonymous
  • 100 Answers
  • Posted on Nov 01, 2010
SOURCE: model g 2401 hb
Very simple fix, I would recommend purchasing a replacement unloader valve, see this link, it should fix your issue
2answers
What is oil type for my pressure washer pump (K2300G)?
PDF]Service Handbook High-Pressure Washer Pump 3.532-629.0
www.mymowerparts.com/...Pressure-Washer.../Karcher-Pressure-Washer...
Sep 28, 2001 - For Karcher Pressure Washer Parts Call 606-678-9623 or 606-561-4983 .... Oil Bath. The swash plate and pistons are bathed in oil. (oil type ...
Oct 21, 2015 • Garden
1helpful
HOW MUCH OIL DO WE PUT IN KARCHER3030B AND WHAT SORT OF OIL
you need to know where oil is coming from. pump or motor? both will use normal motor oil
Oil type in Karcher gearbox
If you are talking about the water-pump gear box only, the correct oil type is 30W NON-Detergent oil. "ONLY"
7helpful
Need to know what oil to use for oil change in the kracher by honda
engine oil....10-30...sh/sj.......19.52 oz do not over fill
oil in pump is a special oil through karcher....3.52 oz of pump oil
30helpful
2answers
How to put oil back into the Karcher water pump
You need to remove the pump and sit it brass side up before removing the bolts holding the brass to the aluminum part (you have to do it that way so the oil doesn't spill out.) CAUTION: there is some spring tension on the brass head.
Take the brass head off and set to the side on a rag or in a bucket. Dump out whatever oil is in the oil side, making sure not to drop the swash plate or bearing (the pieces sitting in the oil). Fill the oil end with aproximatly 4.5 ounces of Karcher pump oil, (or just 20w 50 weight non-detergent oil). Put the brass head back on and tighten bolts. Put the pump back on the machine.
If this helps please rate.
Bill
2helpful
Need to know what type of oil is to be used in a pump assembly for a karcher G 2600 ph
Hello:
10W30 oil but make sure it is NON DETERGENT. Also be sure the reservoir is only 1/3 to 1/2 full
7helpful
Dear glenoaks06,
Regards,
Fulltech.
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
