Blew mega fuse jumping off battery wrong. replaced mega fuse now it wont start. has bean idling low before this happened
SOURCE: car wont start
sounded like the altinator, when you replaced it did you plug it in and check it.. Thanks wired good luck
SOURCE: my kill switch fuse blew on a 1994 chevy surburban
If the fuse blew than you have a short follow the wire and see where it shorted to.
SOURCE: 98 chevy cavalier 2.2....replaced starter...car
Sounds like bad battery cables and/or ignition switch. I would clean battery cables thoroughly with wire brush especially the bottom end since they're exposed to road grime, etc... Also check to make sure you put small wires on solenoid on correctly. I've seen people get them reversed because they're looking at them upside down when attaching from under car. More than likely it's those small wires on solenoid.
Check dimmer switch, replace if needed,'
Check light sockets and wires, replace as needed.
Check for relay if applicable.
Can the mega fuse stop your alternator from charging
