Generac 10000 elx model 9801-1 125v at idle and 150v at operating speed. new control board #96476, new power regulator #92769 still same results.
SOURCE: no power output from a generac c5000 generator
First check the circuit breakers on the control/outlet panel.
Then take the end off the generator and look at the brushes (usually what breaks) and the 2 slip rings they ride on (these get dirty and have to be cleaned off with a bit of emery cloth)
Then look at the voltage regulator (the little board that the brushes plug into)
Let me know if you need more detailed help,
Carl
SOURCE: Honda EMS 4500 Generator - High Voltage Problem
As far as I can tell on the wiring diagram for this generator there is no voltage regulator unless it's incorporated with the auto throttle unit.
To lower the voltage you need to lower the speed of the generator engine. To do this there should be a screw on top of the engine under the tank when your facing the recoil. This screw presses on a arm that controls your governor. Turning it in (righty tighty) will increase rpms, turning it out will lower them. You should see the voltage change on the voltmeter.
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
