<p>Sending images is easier than ever to do with Bluetooth. The
Bluetooth function is a wave viable communication link allows electronic
devices to share and transfer media such as photos, music and even videos
without any physical connection. In most cases, users choose their cell phone
to send pictures to the computer as a way to upload. However, most of the work
is done by phone. By setting up user, you can use the Bluetooth function on
their mobile phone or computer to easily send photos for free. <br />
<p>1. Press the phone "Menu" or "OK" button
and navigate to the Pictures folder on the phone. <br />
<p><br />
<p>2. Search photos stored on the phone and find the photo you
want to send images from the phone directory. <br />
<p><br />
<p>3. Press the right phone, the pictures "menu"
Options. "Select the action" Send Options "pop-up menu. <br />
<p><br />
<p>4. Select the "Bluetooth" option to send the
submenu. You will be prompted to power the phone's Bluetooth component. <br />
<p><br />
<p>5. Press the phone "Menu" or "OK" to
"Yes" option and confirm that the Bluetooth component. Bluetooth
phone menu opens automatically. <br />
<p><br />
<p>6. Select Search to search for compatible Bluetooth-enabled
electronic devices by selecting "Browse Device" option in the
Bluetooth menu. (The phone must be connected to the receiving device for photos
sent successfully.) Component Bluetooth phone will start searching for devices
within easy reach. <br />
<p><br />
<p>7. Select receiving electronic device is the name of the
list of Bluetooth devices from your phone lookup. A request to accept photos
sent will be sent to the receiver. If the request is accepted, the image is
automatically sent from your phone to the receiver. <br />
Kindly try and configure once again.
Open phone settings and select bluetooth to be ON.
Now open the bluetooth manager in the PC as the phone will be identified .. set passcode.
Now open the images to be send and select the mode as bluetooth.
It will be send and received in the bluetooth information exchange manager in the PC.
Go to the photo you would like to send, select the option to send via bluetooth. Make sure the other device is near and has bluetooth on. Select that persons bluetooth signal and follow the prompts to pair/send the image via bluetooth.
soln 1
have u checked tryin to transfer data of pretty small sizes like an image?
soln 2
1. On the receiving device, go to media, select what you'll be receiving (photos, ringtone, etc), press menu, then select receive using bluetooth.
2. On the sending device, send using bluetooth...
MUST BE DONE IN THAT ORDER!soln3Go to Applications, then choose Files. Then hit the menu button and scroll to Receive Using Bluetooth. Then on your computer choose the file you want to send and tell the computer to Send To Bluetooth device. It works! Halleluiah!
Get a bluetooth adapter for your pc (USB) these are quite cheap. Then just send a file by right clicking on the file, and going send to, bluetooth device. The wizard will then ask you some questions. answer them, and select your device. Accept on your device.
Hope this helps,
06castwo
o send a file via Bluetooth:From the Start-up screen select the Main Menu icon Go to Multi-media (Figure 1) Select My Stuff (Figure 2) Go the images/sounds/videos/documents and select the file you wish to send Select the Menu icon at the bottom left of the screen Select Send Via (Figure 3) Then choose Bluetooth (Figure 4) You will then be presented with a list of devices in your area. (Figure 5) If you do not see the device you wish to send your file to ensure it’s has Bluetooth switched on and select New Your handset with then search for all Bluetooth devices in your area (Figure 6) Select your device and your handset will send the file (Figure 7) The Bluetooth device you are sending your file to must accept the file (Figure 8)
To receive files via Bluetooth ensure you have Bluetooth switched on – only accept files from devices you recognise. You will receive a message stating the file name with the option to accept or reject the file To receive select Accept (Figure 9) The file will then be transferred to your handset (Figure 10) It will then be saved in your images folder
