Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
Posted on Jan 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony KDL-40V2500 Screen is white
My sony has issues!! When you turn it on there is sound, but picture is almost a white out. You can see the picture in the backround but the screen is basically white. Can anyone help. I am hoping it is not the panel itself. Is there a way to tell if its the panel vs a replaceable assembly?
Larry
Level 3:
  • Sony Master 5,042 Answers
  • Posted on Jan 31, 2018
Larry
Sony Master
Level 3:
Answers
5042
Questions
Helped
1241776
Points
18413
Remove the LVDS cable, the one going to the input of the tcon board and see if it goes dark, if it does the Tcon board has failed
5 Related Answers
AMJAD HUSSAIN
  • 586 Answers
  • Posted on Aug 06, 2008
SOURCE: sony kdl-40v2500 40
It must be due to the timer which is in Active position.Just check the both timers sleep and On.
Anonymous
  • 320 Answers
  • Posted on Oct 18, 2008
SOURCE: Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Chi Chu
  • 8457 Answers
  • Posted on Dec 17, 2009
SOURCE: broken screen on a kdl-40v2500
No not repair able very expensive,LCD screen will cost the same as a new tv.Tv compannies will not sell LCD screen out reasonable price.
djchillsnyc
charlie rodriguez
  • 152 Answers
  • Posted on Dec 25, 2009
SOURCE: lcd is cracked on a kdl-40v2500 soney
hi, if your screen is cracked you will need a replacement screen this type of repair that if you call a service center they wont do becuase basically the screen is the most expensive part it may be more than the cost of the tv when new, theres only one way to do this and not spend a fortune and thats by buying a used tv same model that is not working or for repair, of course it needs to have a good screen, where at auction sites and surplus sites. you can replace the screen if you buy a used non functional at auction and exchange it or repair the other tv with your parts either that or get a new set, it is expensive to fix any other way. hope this helps, happy holidays.
Anonymous
  • 148 Answers
  • Posted on Feb 03, 2010
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
2answers
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
2helpful
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
1helpful
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Hope this helps you...
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Repairing Sony LCD tv
Try getting the TV menu on the screen. If you can't, it's probably the LCD panel or backlighting issues. If you look very closely sometimes you can see a dark image if it's backlighting issues.
If you can bring up the menu, but all inputs are black, then the problem is more towards the electronics. Usually computer VGA and HDMI inputs bypass a lot of electronics and may point you to a video switching issue in the TV. If this is all Greek, consider a trained service company. Choose a platinum servicer since they are Sony trained, certified and held to much higher standards than other authorized servicers. Sony expects them to make first attempt fix within 5 days of contacting Sony. Usually the right part is sent to the tech prior to them setting the repair appointment. Compare that with the others and you will see a clear difference.
Connecting up Sony Digital Camera
If you have still black n white jumping picture then please go to camera menu and change Video Out format to either PAL or NTSC, close menu, power off camera and power it up again and check.
Picture turns off sound is on
Hi Anya, Im sorry to hear of your difficulties but very happy to know im not alone. I have the same exact Sony model and the same exact problem. I wasnt sure if it was my Tv or my upconvert Sansung DVD player. I spoke with Sony assistance..and well..they were of no assistance. They blamed it on my HDMI cable, then the dvd's i was playing, then the dvd player itself. I ruled out all of the above. Mine goes black when i play a dvd in the upconvert format (720p or 1080i) otherwise known as digital..but the analog signal goes through fine. Luckily i am within my 30 days since I bought it, so now that I have seen your posting and am certain its a tv issue, I think i will return it and buy a Samsun tv (a great alternative for same price with only drawback being a glossy screen=not good for bright rooms but amazing color clarity). Sorry I dont have answer for the problem other than your not alone on this one. I have read other Sony users listing similar issues. I hope all goes well with you and wish you the best Matthew
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
