Have removed light cover but bulb stuck tight
Put a rubber glove on and it gives more grip easy to turn
Put fat rubber bands around the cover to get a better grip.
I boiled the kettle, added the hot water to a tray and placed it in the oven, shut the door then left it for 10 minutes so it steams up the oven (make sure power is off first). Do the same again. Then get a multi grip spanner and place a kitchen rag over the cover and turn to the left. It does take a bit of force depending on how stiff it is, but the steam will loosen the cover. The steam also cleans the oven quite a bit too!!
SOURCE: unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
