I use a mini -to -rca stereo audio cable to hook my Ipod up to my onkyo sr 506, I've hooked it up to the tape first then aux, I'm still not getting any sound. HELP!
We have an Onkyo TX-SR502 and hooked our ipod up to it using a stereo mini to 2 audio cables. However, we can only get sound out of one side of speakers now. If we switch the left and right audio plugs the other side of speakers will then work. How do we get the left and right speakers of A and B to work? The A and B speakers are both selected.We have an Onkyo TX-SR502 and hooked our ipod up to it using a stereo mini to 2 audio cables. However, we can only get sound out of one side of speakers now. If we switch the left and right audio plugs the other side of speakers will then work. How do we get the left and right speakers of A and B to work? The A and B speakers are both selected.
You can't post conmments that contain an email address.
I pods use a different adapter for doing this. It plugs in the bottom using the big porton bottom and outputs the rca plugs this way. Ipods see too much resistance and protects the unit from burning out. check this out http://www.amazon.com/Logic3-iPod-RCA-Phono-Cable/dp/B00083D7WC
You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1 . Connect from the headphone port of the iPhone and use the red & white RCA audio cables to connect into the RCA audio input terminals of your TX-8511.
To hook up your ipod to an a/v reciever you need a stereo mini to male rca cable. You plug the mini side into you ipods head phone jack, and the male rca's left and right(usually red and white colored plugs) to an auxilary input on the a/v reciever.-Example, tape, aux, sa/cd.
Change the input on the reciever to correspond with where you connected the ipod
Ensure the ipod is powered on and playing with the volume turned up.
u need this (search ebay.com)also u can make this cable easily.
3.5mm Mini Plug to 2-RCA Stereo Audio
Cable. plug 2 RCA jacks to (Aux in)socket on your Receiver,3.5mm Minijack to your Laptop's speaker out.select AUX input on your Receivers Remote .
use your headphone jack, you will need an adapter cable that converts the signal to left / right male RCA jacks. (available at radio shack or on ebay)
these can plug into any red / white inputs EXCEPT phono I use the input labeled CD for my blackberry to listen to MP3's and stream music from Pandora.com
Use a phono to RCA stereo jack (pic below) and hook one end to the head phone jack on your ipod and the other ends to your amplifier aux or tape input and adjust the volume to low on the ipod - select the input on the stereo - Aux or tape in.
You'll need this type of cable
I am not used to count colors or numbers on wires, but what you did is that you created an oscillator, by hooking up the output of the receiver and ran it through your computer which inverted the phase, so the thing oscillated and committed suicide. Onkyo used to make some good impact printers, before the modern inkjet came around. If your unit is within warranty, don't hesitate to go where you bought it and ask them to re-imburse you. Receivers don't blow up just like that, because someone hook a wire wrong. One of the specifications is to check just that: phase reversal and oscillations... My name is Constantin (arzconst is my internal nickname with fixya.com)
I connect my iPod to my Onkyo using a stereo cable with mini-plug on one end and RCA L&R outs on the other. Just plug the RCA plugs into the AUX or TAPE IN on the Onkyo, and the stereo mini plug into the iPod and play as usual.
The simplest solution would be connect the headphone jack on the iPod to the stereo audio inputs (RCA) to your home theater. So you need a cable that is "stereo phono mini jack" on one end (into iPod headphone jack), and then Y-splits into two RCA connectors on the other end (into L and R audio in on the receiver).
The expensive Apple-endorsed Monster-branded version can be found at http://store.apple.com/us/product/TN983LL/A#overview for $30, but you can get the same thing at Radio Shack for $7. http://www.radioshack.com/product/index.jsp?productId=2102974&cp=&sr=1&origkw=phono+jack+rca&kw=phono+jack+rca&parentPage=search
Set the iPod volume to less than ~80% and then control the volume using your receiver. You have to use the iPod menu to select music.
THe easiest way to hook an iPod or any other personal audio player to almost any audio receiver is to pick up a cable having a stereo miniplug (like the plug on your earbuds) on one end, and two RCA plugs on the other end. You should be able to get this cable from almost any electronics or discount store for under $10. The miniplug goes in the iPod's earphone jack, and the RCA plugs connect to an unused input on your receiver. Inputs marked "AUX" or "CD" are a good choice, or even a "TAPE" input. Set the iPod to about 3/4ths volume and adjust the receivers controls for desired volume.
