When I turn the camera on to record or take pictures my screen is black. There is no picture in the viewer. And when I try to take a picture it is black.
Could be a problem
with the LCD screen viewer or CCD Image sensor go to bad. In both cases this isn't a job that you could solve yourself; this wrong include
distorted images or abnormal colors, scratchy purple lines, blank or
black pictures, and/or black videos with good sound being recorded on
the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Olympus service. Istrongly suggest(taking intoconsiderationthe age of yourcamera) to evaluatethe cost ofrepairversusthe cost of anewcamerawith similarfeatures,before making afinaldesicion.
Could be a problem with the LCD viewer screen, or,
if not, could be the CCD image sensor go to bad;
in both cases this isn't a job that you could solve yourself; this wrong
include distorted
images or abnormal colors, scratchy purple lines, blank or black pictures,
and/or black videos with good sound being recorded on the camera's flash
card. I
CCD (Charge Coupled
Device) and next contact your Kodak service. Istrongly suggest(taking intoconsiderationthe age of yourcamera) to
When you transfer this pics at pc... they are black
too? Could be a problem with the LCD screen viewer or CCD Image sensor
go to bad. In both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card.
I
CCD (Charge Coupled
Two things there, first... could be a problem with the viewer screen, or, second choice could be a problem with the CCD sensor or go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines,
(Charge Coupled Device) and next contact your Canon service. Istrongly suggest(taking intoconsiderationthe age of yourcamera) to evaluatethe cost ofrepairversusthe cost of anewcamerawith similarfeatures,before making afinaldesicion.
The problem is with the software in the camera! So take your camera to the nearby service center and do a format of your camera! That will fix your problem. Also check whether there is any problem in ur LCD screen!
If your camera got moisture inside and you turned it on before it had a chance to completely dry (usually takes several days) you may have caused a short circuit.
Its bad ccd imager in camera and this part will be replaced. Canon will repair Free of Cost A75 camera as per announced scheme. Click Canon CCD Imager Advisory for details.
If you take a picture using the optical viewfinder, does the camera actually record the picture? If so, you may have the LCD turned off in the camera mode (there are three options: standard, detailed, and off). With the camera in the shooting mode, press the "DISP" button and see if the LCD turns on.
Hi, Your DSC-T1 has problem with CCDImager and Sony will repair it free of cost. Please click Sony website and confirm camera symptoms and get details to proceed further. Regards,
