Cell Phones Logo
Posted on Feb 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cell phone how do you format the sd card?
Can't format the micro sd card?
Anonymous
Level 2:
  • Expert 96 Answers
  • Posted on Feb 21, 2009
Anonymous
Expert
Level 2:
Answers
96
Questions
Helped
25431
Points
247
Just go memory card in that u find format option
select that & ur memory card will get format or try connectioning ur mobile to pc & format through pc by selecting memory drive right click mouse button select format option in that asked for quick & custom format select one of them & format ur micro sd card
Anonymous
Level 1:
New Friend:
  • Contributor 42 Answers
  • Posted on Dec 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
42
Questions
0
Helped
16353
Points
18
Just go the memory card and there is option to format or just insert the card to the computer through a memory reader and open my computer and right click on memory drive then click on format.
5 Related Answers
A
Anonymous
  • Posted on Apr 02, 2008
SOURCE: memory card micro sd cannot format
the card may be formated use window command prompt.
Anonymous
  • Posted on Oct 19, 2008
SOURCE: pny micro sd memory card
Most PCs are like that. I don't know what it is but the computer won't do it for mine neither. To put music and such on you sd card for your phone you must format the card while it's in your phone. Goto setting, Memory, Card memory, then click on opions. From there it will say "Format Card". Do it and the lock code is the last four digits or your phone number. After that's done to load music and such you put the sd chip onto you computer and transfer music to the folder on the sd card called "My_music", pix to "My_pix", and so on....
Anonymous
  • Posted on Nov 03, 2008
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Anonymous
  • 75 Answers
  • Posted on Dec 11, 2008
SOURCE: I can't get songs on my micro SD card for my cell phone
you can get a memory card reader so that you can connect it to the usb port of your computer and you can add songs to the memory card...after copying it just put that memory card in your phone and enjoy hearing songs...
Anonymous
  • Posted on Jun 25, 2009
SOURCE: cannot format PNY 4gb microsd card
I WAS TOLD BY MOTOROLA THAT THE V3M WOULD ONLY TAKE A 1 GB TRANSFLASH MEMORY CARD. I TO HAD A 4 GB MEMORY CARD AND IT WOULD ALWAYS SAY , CAN NOT FORMAT, TRY AGAIN? I BOUGHT THE 4GB AT THE STORE WHERE I GOT MY PHONE. I BOUGHT A 1 GB MEMORY CARD AND IT WORKS FINE NOW. I HAVE NO IDEA WHY THEY SOLD ME A 4 GB IF IT WOULDN'T WORK WITH MY PHONE . HOPE THIS SOLVES YOUR PROBLEM IF YOU HAVEN'T ALREADY .....
How do I activate my micro sd card in my Samsung galaxy grand prime cell phone
Insert your new micro SD card first on the phone then go to settings> storage> format SD card to make sure that the card will work properly.
1helpful
My lg pop wont read the memory card , and my other phones all read the memory card, no matter what memory card i insert to the lg it says" format memory card" then i do and still nothing, could...
I had the same problem with an HTC Aspire ( I think that's what it was called :} Anyway I formatted the micro SD card in fat 32 through my laptop using a micro sd to sd adapter and the sd card slot on my laptop. I then stuck the micro sd card back into the HTC and it worked. I heard formatting through another phone works too. Try it and let me know.
3helpful
I want to format my 3110 phone i need a formating code
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself.
2answers
Micro sd card mp4 video says " playback error"
Sometimes the downlodad file format wont support the the file fornat of the phone .If u are using the micro sd card fo the first time the format the card . otherwise it may have this problem.
Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
2answers
SD Micro card- Formatting
your micro SD card may be damaged in some small way, or the card reader is a defect in it, to see which one it is,
****TRY TO BUY ANOTHER SD card, your phone can support up to a 2 GB micro SD card, if it persists, then *********** board in the phone has a defect.
Cant format micro SD Card
try to reformat the sd card to the required FAT 16.... use a computer..and sd card adoptor for you to connect the card to the computer
tnx
No, Im Sorry But Adaptors Are Incapable Of Holding Memory, And You Shouldn't Take Out The Micro SD Before You Remove The SD Card, You Should Also Try Putting In The Micro SD Card And Going To Tools And Enter Into The Memory Option And Selecting Card, Then Using The Options Button Format It, Then Put It Back Into You Computer And Save All Your Songs To The Folder Named my_music This Should Work, And Just So You Know The Phone Will Not Play All Of The Songs That You Put On It For Some Reason, Its Some Formatting Conflict The Songs Can Be In .wma Format Or .mp3 not .mp4 or any other types.
Tim2o9
1helpful
2answers
Micro SD card
try to format it using your computer.
Connect the card with computer using a card reader
Then go to my computer right-click the micro sd-card and select format. Format it using FAT.
5helpful
Need to reformat micro-sd card in up stage phone
to reformat micro sd card in your phone
go to menu>my stuff>select removable disc or memeory card then select options>format
>>or you can reformat the micro sd card using your pc
>>connect the sd card to the memeory card reader then connect it to the memory card adapter
>>go to my computer then select removable disc then right click then select format
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
