Proform 280 CSX Upright Bike Logo
A
Anonymous Posted on Mar 03, 2013
Proform display not working - Proform 280 CSX Upright Bike
Megan Balabon
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 22, 2021
Megan Balabon
Contributor
Level 1:
Answers
Questions
0
Helped
3060
Points
Having the same problem
Anne Freitag Jones
Level 1:
New Friend:
  • Posted on Mar 12, 2019
Anne Freitag Jones
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3060
Points
My Screen on my Pro Form 325 CSX exercise bike Only says Hello
How do I fix this?Do I need to activate at IFIT.COM?
Proform elliptical 825 can't get the display to stop blinking?
If you are not working out on your trainer, the display should flash for a while and than completely stop. But if it continues to flush, please call proform support.
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Proform ZT5 Treadmill, PFTL60509. The display works but the light has burned out. I'm not sure if it has a bulb? Can I fix the light without having to replace the console?
No don't light only seven segment display, you must replace the complete display board. go to www. fitnessrepairparts.com and get it
of course try if the ribbon cable is loose, or dirty, and clean with contact cleaner and try again. However you must try to adjust the REED swtich, and adjust it.
Proform Crosswalk display will not work. Belt and incline work fine. Have changed batteries, adjusted reed switch to within 1/8
adjust the REED switch, see the diagram for to do it. clean, and tight the connector very well.
God bless you
New console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Proform treadmill zt 5 runs but display is dead
If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
The console of my treadmill displays time and speed incorrectly
Hi. if you are talking about the same segment in all the characters of your display being lit, then it is a console problem - it will not be a hard thing to fix but you will need a board level electronic serviceperson to do it for you
Proform 755 Treadmill display color problem
Please check your Adaptor Current Rating
sada
Top Proform Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Proform Cycling Expert? Answer questions, earn points and help others
