The knob might be stripped not focusing
First of all, make sure the projection lens is correctly inserted. The gear "rack" that runs down the side of the lens correctly should mesh with the white or black gear (color depends on gear vendor) that is pressed on the focus shaft.
Check to make sure the focus knob is secure on the focus shaft (when you turn the knob, the shaft should turn, too).
Finally, remove the projection lens and inspect that black or white gear on the focus shaft inside the projector: Is the gear present, and are all the teeth on the gear?
One or a combination of these 3 issues are more than likely the cause of your problem.
Let me know if I can assist further !! Jim
