Microsoft Zune JS8-00001 Digital Media Player Logo
Posted on Feb 20, 2009
My zune wont properly start up
I turn it on, the zune logo appears, the bar fills up.  no problems with that.  Then when that logo is done it just goes to a blank screen.  I can't do anything, I plug it into my computer and the zune program doesnt recognize it, it just stays on that stupid blank black screen.  Ive let the battery die and i plug it in and it shows the charge icon then goes to the same blank screen.  help!
  • funkymonks27 Mar 10, 2009
    thanks rokus you rock us!!!
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Mar 08, 2009
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
15773
Points
39
Have a zune 120g thqt displays a 5 and zune player with a X in the screen. And it says to contact support. It wont cut off or reset it wont do anything at all.
hold the back button and the up button until you see the Zune logo then release. if this doesnt work then you are going to have to reset your Zune....however this will loose all the data on the zune so your music/movies will be completely gone. you are going to need to press and hold the back and up button until the zune logo appears then hold the back,play/pause, and the center button until you see "please wait"
if this doesnt work you have some serious issue.Source(s):
My zune is lock up what do i do
To reset the zune,
1. Make sure that the Hold switch is turned off. 2. Hold down the Back button and Up on the control pad until you see the Zune logo appear on the screen.
Once the device finishes starting up, your Zune should function as normal. This procedure will not delete any of your media files.
2answers
120GB Zune wont turn on
Please try to hold Back, Center and Left at the same time to restore the zune,
Zune 30gb wont start
Update the firmware in that zune and you should be doing great if not microsoft has recalled some of there 30 GB versions due to the latest zune error.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
3answers
ZUNE FROZE WITH LOGO AND PROGRESS BAR
This is a fatal error porblem. If you go to the Zune Microsoft website you will find many others have the same problem. There is no fix for it as of yesterday afternoon. We have had problems with our 30 and 8 gb Zunes and finally returned then to Best Buy and got IPods.
Frozen screen
Got it working again. Disassemble and disconnect the batery for about 10 seconds. This worked to resent mine and it's working again. Not sure if it's permanent, but working for now.
Disassembly instructions:
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
1helpful
Zune Froze, erased content, and wont sync with PC.
Yes. There are several solutions to this. Rather than retype them, you may want to check out the forums at www.zune.net or support.microsoft.com.
Most likely you'll have to remove the Zune software from the PC, re-install it, reset the Zune.... I think you get the picture.
Top Microsoft Audio Players & Recorders Experts
john h
Vinho Xie
Vinho Xie
Rick Rock
Rick Rock
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
