Lexmark X4550 InkJet Printer Logo
sharon double Posted on Mar 03, 2013
Paper will not feed to print - Lexmark X4550 InkJet Printer
1helpful
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
1helpful
2answers
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
3helpful
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
2helpful
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
