Check this site http://www.howtomendit.com/answers.php?id=180324. hope this helps
SOURCE: my freespirit treadmill showsL5 on nthe display then quits
If calibration doesn't work replace controller.
SOURCE: My Freespirit treadmill is asking me to put on the safety key i
Sounds like the internal switch has ether move position or has become defective. You Will have to remove the upper console and locate the switch either on upper electronics or the console assembly have a ohm available when using the key to engage the switch you'll see if its working properly
SOURCE: In the middle of a
hi,
ERR 05 always means speed sensor problem.If it is defective or loose contact will always cause this issue.The sensor controls the pulley belt to rotate.So your treadmill is not working.
You need to pull the cover off. Check for burned wire or short circuit on the board and loose sockets.
Use multimeter to test the sensor.
I have common service Treadmills manual.Use it for having some idea.
http://www.casallproducts.com/swe/pdf/Servicemanual/Vision/T9600-T9700.pdf
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
