Televison & Video Logo
Posted on Mar 03, 2013
Sound no picture on my teac tv
I have sound and no picture please can you help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
323
Points
If you are using RCA plug cables or an HDMI cable it may be that. Try
the input button on your remote to see if the tv is set in the proper input
channel. Disconnect everything, then reconnect and try again.
Teac set top box hd860 showing black and white picture on tv and NO sound
Hello Rosemary, it is very possible that you have your Teac HD860, in another television color standard (PAL) and not in NTSC, this you can check it by entering the Menu
Follow the steps indicated on page 17 of the user manual of your Teac
I sent you the link so you can download it
I hope you have the programs in colors again
Greetings Franco Dosil
Hola Rosemary, es muy posible que tengas a tu Teac HD860, en otra norma de color de television (PAL) y no en NTSC, esto puedes comprobarlo entrando el Menu
Sigue los pasos indicados en la pagina 17 del manual de usuario de tu Teac
Te envio el link para que puedas descargarlo
Espero que vuelvas a tener los programas en colores
Saludos Franco Dosil
http://www.teac.com.au/downloads/product_downloads/HDB860_IM.pdf
1helpful
TEAC Axia TV Model: LCDV 2605 set up to use surround sound speakers. Wish to revert to TV's own built-in sound system speakers only. Do not have a manualas was gifted a second-hand TV. Help?
If you have the remote, simply go into the audio menu and check TV speakers. If you don't then you'll have to either purchase a duplicate remote or find a universal which will allow you to access the audio menu of the TV. I'm afraid there's no other way that I know of. Good luck. So, you have no sound at all on the TV as is, correct?
1helpful
Sound from anything but cable?
Is my TV Teac model LCDV 2010M suitable for connection to digital TV or do I need a "box" for it?
3helpful
2answers
I have a audiosonic kgr1 remote and need the set up instructions and teac tv codes
You're in luck - try each of these 4 digit codes for TEAC TV:
1627 1085 1152 1154 1165 1168 1171 1181 1183 1193 1283
No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
I dont have manual and i am trying to find and set channels on my teac sdb450 set top box
43D8UXA Toshiba TV - DVD playing with sound. No picture on tv, Playing normal tv but not DVD.
worked 2 days ago. How do I adjust the tv to get picture?
Hi, I bought a teac dvd and 5 speaker surround sound system yesterday. I am having trouble setting it up. I want to run the TV sound through it as well, but at the moment it is only going through the sub...
Whoa,ok.Sounds like things aren't connected properly.The first step is to disconnect the TV and concentrate on getting sound from a dvd or cd.Read the owners manual and double check that the speakers are hooked up correctly and that the unit is in the correct surround mode.Next, connect the TV.Use an RCA cable to go from an "Audio out" jack on the TV to an input jack on the Teac -e.g. "Aux, TV, etc.If your TV doesn't have the proper jack, I'm afraid you're out of luck.
1helpful
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Sound but not picture, a black screen
Hi gp63
you will need to change the settings of the tv to ensure that it is on the right mode. ie. av1, av2, dvd, what ever the settings you have used for your tv.
good luck
smeags.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
