Try these WEB sites.
RESET NOKIA SECURITY CODE
http://tjosm.com/reset-forgotten-nokia-security-code/ if it does not work use nemesis service suit http://mastercode.nokiafree.org/
SOURCE: Resetting Security Code
6003104322
This code will reset any security code on your phone to one of your choice.
for 5300
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
SOURCE: 6233 security code unlocker
i have forget PW to unlock phone lock. My IMEI is 359727006727643.
SOURCE: security code nokia 1650 ?
try the Default security code is 12345
then try this code
*#7328748263373738# resets security code.
SOURCE: nokia 6300 security code reset
@ Chaina6300:-
This is the Master Reset Code for Nokia 6300 for your IMEI.
IMEI: 358649015418942
Master Reset Code: 7740552014
___________________________________________
@jsisonunderg
The Default security code for Nokia 6300 is 12345
@ viva house
Can you tell me your IMEI no?
It can be get by Pressing *#06# on your Nokia
