SOURCE: Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
SOURCE: need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
SOURCE: cuales son los codigos para ajustar la imagen de
You have bad capacitors near the vertical IC. And you might have some one change the two horizontal caps as well. One is 250volts 2.2MF and the other is a 25volt 47MF. The caps near the vertical would include a 35 volt 100MF, two 50 volts 100MF, 50 volt .1MF, 16 volt 100MF and a 50 volt 10MF. If the fuse in your TV is good...you will not have to change any semi conductors [ICs].
Testimonial: "gracias si me sirvio su ayuda el condensador dañdo fue el de .1mf 50 voltios. gracias otra vez."
SOURCE: I have a curtis mathes/tronics tv Made in May/2001
No need for the tv manual.Just follow the basic hook up instructions in the booklet came in with the Converter box.Very easy use channel 3.Use the codes for Curtis-Mathis tv in the booklet for the remote.I hook this Exact model of tv is take 20 mins.
SOURCE: does my curtis mathes tronics tv model CM19011
No,all CRT tube tvs don't have digital tuner inside.They're analog tvs.Must buy the converter box,and hook it up to get the free DTV airwave signal.Trust me,i help an elderly person hook up this exact this tv model with a converter box.Try buy the RCA model converter box,it matches with this tv model very well.
