Can't remove chuck, change attachments
SOURCE: dremel 400 xpr stopped working.
It could be the fuse between the brush and variable speed control switch. I have the same problem and found the fuse blown. I am hoping that I can replace the fuse without having to buy the complete speed control unit which is about $17.00 from Dremel. If yours is still under warranty you could send it back. If I can find a fuse for mine I will let you know where to get them. joatmontag
SOURCE: How do you attach a wheel cutter to a dremel 400
Go to Dremel.com and download an owners manual for detailed instructions for this tool.
SOURCE: Dremel 400 xpr stopped while in use and started to
its a comon thing with a dremel to just burn out in use iv got through 3 of them all died the same way
SOURCE: Is the bigger Dremel 400 XPR coming to Australia ?
yes already there you can buy at Just Tools
SOURCE: I have lost my user's manual for the Dremel 400
you can try going to "dremel.com" and downloading the manual, also there they have a toll free number for tech support which might be able to send manual as a PDF file. Let me know if you have trouble finding it and I will come up with another source
