Lost instructions for casio g-shock silencer. how do i set the watch up or were can i get a copy of the instructions
Heres a link to the PDF of the manual for the
G-Shock Silencer series.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2931.pdf
Good luck,
Techjoel
SOURCE: i have a Casio G-Shock GIEZ GS1100-1A watch and
http://world.casio.com/wat/download/en/manual/
SOURCE: adjust the time in a casio g-shock shock resist watch
You can get instructions from the Casio web site.
Go to the
casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read
the number of the back of your watch and enter it into the search box
Click
on "search" and the download your instructions.
SOURCE: how do you set the time on a casio g shock watch????????
I had the same problem following recent daylight savings time (DST) change. The watch has three DST mode settings (ON, OFF, and AUTO). You get to the setting mode by pressing and holding the "adjust' button until the city time zone indicator starts to flash. Then press the "mode" button. This should give you the DST setting. Now press the "receive" button to cycle through the ON, OFF, and AUTO modes for DST. I set it for AUTO. I then existed the setting mode by pressing "adjust" again.
Now you can initiate a manual update of the time by pressing and holding the receive button. Put your watch by a window and make sure the signal strength indication is showing level 4 (full picture of satellite dish on my version). Give it a few minutes to down load new time.
After doing this the watch corrected itself and now shows correct time. Other wise I assume you could set the DST function to ON or OFF as well depending on whether you need to add or subtract the hour from the time.
