My admiral washer will fill up on 1/2 the way full but water is still on as if it is trying to fill. So, the water keeps going and going but the tub only is 1/2 full. If the water level control is set to a low level, the water stops filling and the tub begins to cycle
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
I have a GW512 that only on low level will keep filling until i turn the tap of manually and then works fin
keeps filling when it should have turned off
