Starts for 30 seconds then cuts out no revs,nothing happens when you try to accelerte lim and dtr sign comes on,i have changed all coil packs
Is engine running on all 4 cylinders when it starts? If it is not it may be the control module on the inner wing under windscreen washer bottle, failure of this module is very common. You should have a scan done to check trouble codes as the control module, is very expensive, good used control modules are available on eBay
SOURCE: how to reset the airbag sign of a mercedes benz R reg C180
u can do nothing...
a fault contain in the airbag system...
wat u can do is send ur car to the workshop which got STAR DIAGNISIS to scan wat code is that..
SOURCE: mercedes c180 fuel gauge giving mix reading
You can try to clean the ground behind the instrument cluster to see if that helps but most likely the sending unit has gone bad in the gas tank.
SOURCE: i have a c220 mercedes and have had problems starting the car
sounds like wiring problem engine harness
Testimonial: "OK THANKS FOR YOUR HELP, I HAVE CHECKED THE WIRING HARNESS AGAIN AND HAVE NOTICED THAT POWER TO NUMBER 1 INJECTOR DISAPPEARS AFTER THE INITIAL CRANKIN"
SOURCE: Mercedes c180 2002 model
Well the first thing i would do is scan the computer for codes,but without a scan reader you cant. see if it has fuel preasure,start there.
