SOURCE: Mercedes Benz C180 Fault Message Brake Assist.Visit Workshop BAS
Hi there
BAS is the Brake Assist System and if there is a malfunction it would
only come into play in an Emergency stop while applying full pressure.
BAS applies full braking force because people tend to lighten up their
pressure on the pedal in these situations. I would suggest that the best thing to do is go to a Workshop or Service Center and have it checked out. Please remember to put a good rating on my profile.
Kind regards
Dustin Ellse
SOURCE: mercedes benz bas/esp light on
Change the brake light switch first, its on the brake pedal, £9 from mercedes.
jib
www.mercanic.co.uk
SOURCE: esp/bas light on, steering wheel off center after off roading
If your steering wheel is off center, this can cause the problem. Luckily this is very easy to fix -- you can do so even if you have little to no experience working on your vehicle.
1. Park the vehicle with the wheels facing straight ahead (drift forward until you are moving in a straight line). Don't worry about the steering wheel position.
2. Locate the steering drag link -- the diagonal rod coming from the bottom of the steering arm to the top of the passenger side steering knuckle (on the axle near the tire)
3. Loosen the two bolts on the rotating adjustment collar on this link. I believe these are 13mm.
4. Rotate the collar one way about two or three turns, check the steering wheel to ensure that the "Jeep" logo is perfectly horizontal. If it's not, continue rotating the collar (or move it in the opposite direction) until the wheel is centered.
5. Tighten down the nuts on the drag link adjuster.
6. Take her for a test drive and let me know how it worked!
Could it be the K40 relay, it appears to have a small amount of heat damage but no cracked solder on the circuit board. Pulled it out last week out of curiousity because my seats work intermittently. Any ideas?
Why you flush brake,could be bent wheel,worn out tie rod or you hit something.
