HP Photosmart C3180 All-In-One InkJet Printer
You may download and/or order the latest software and drivers from here.
SOURCE: making my printer wireless
you can by a apple (mac) airport module and hook up to your printer and it will work
SOURCE: can not locate and download 64 bit version of HP 2840 laserjet printer driver
What a bunch of nonsense. HP obviously wants us to purchase the newer model of their laserjet, which I did. I was completely unsatisfied with it, so went back to the task of compatibility between my Windows Vista 64-bit system and my tried and true 2840.
Windows has a "Virtual PC" that you can download free. It requires Windows Vista Ultimate, so upgrading was step 1.
Step 2: Download the free Virtual PC 2007 and install it on your 64-bit system: http://www.microsoft.com/windows/products/winfamily/virtualpc/default.mspx
Now that you have your virtual PC (like a mini computer inside your computer) you need to install an operating system. I bought Windows Vista Business version (32 bit) because I found it inexpensively, but you can install whatever 32-bit system that is compatible with the 2840 software. So now you've created a 32-bit virtual system within your 64-bit system.
Now just install the 2840 software into the 32-bit virtual system and you're good to go. All this cost under $300.
SOURCE: hp C3180 printer prints test page every time i turn it on
You were being cheap when you ran out of ink and replaced only the Black Ink Cartridge.
Replace the Color Cartridge and the test page will stop printing when you turn it on.
SOURCE: hp psc 1401 printer driver issue for windows 7
You have downloaded the driver but have you installed it. I would check to see that your printer is using the new driver. Here's a link to a Microsoft site that details how to install printer drivers. Hope this helps and I'm not just telling you something you already know. Good luck!
http://windows.microsoft.com/en-US/windows-vista/Find-and-install-printer-drivers
SOURCE: blinking/flashing lights(orange & green) &
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head
install both cartridges on ur printer n check ur blinking light on ur printer
that will work only if u r too lucky other wise u have to purchase a one cartridge.
