The TV works well EXCEPT for HDMI 1 port, which is dead.. The HDMI 2 works correctly. A nearby lightning strike hit the coax cable and fried a part on the cable. I talked to the Comcast technician who was working on the cable to fix it. Is the HDMI 1 circuit board in the TV a user replaceable part, and if yes, how much does it cost? If it is a simple matter of pulling out the old circuit board and inserting a new one, I can handle that job. [email protected]
Lighting cable perfect forevery house hold ,when you want to use your device in bed or other on soft place Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters Lightning Cable USB Charger...
Yes the board is available at the following link http://tvrepairworld.com/sony_lcd__plasma_tv_circuit_boards
the board with the HDMI on it is listed as the Sony FB3 Board 1-873-850-14
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
SOURCE: Sony Bravia KDL 52Z5100 - no sound only picture.
A short fix is to unplug the hdmi cable and shut down the tv compleetly, then get the tv on and plug it in, the tv see the new connection and reset the value's for sound
