I was faced some problem in dignostics error code is 0146. what is the problem and how can solve the problem.send me immediately
SOURCE: to solve code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
SOURCE: code error 0146 and 0148
Hi there.
0146 error is DST Log contains previous error(s).
0148 error is IDE ERROR: status (x) (s)
This could be a problem with the BIOS, restart the PC and hit F2 as it starts up, this will take you into the bios, reset the bios to default setting, press F10, save and exit the bios, the PC will restart so perform another check and see if the same error code return.
Good luck
SOURCE: Error code 2000-0146
I had the same problem and came across the following solution that worked for me as well:
Re: windows Vista will not start
18 Aug 2009 07:28PM
I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
SOURCE: error code 2000-0146
you Hard Drive is About to fail soon back up all your data and have your HDD replaced ASAP, the longer you use the Hard drive it just may fall to a point tha you get the S.M.A.R.T error which is an HDD error as well replace you HDD asap ^_^ back up data if possbile ^_^
