Yup, you said it yourself, Your a parts replacer and not a mechanic. I understand friend. Your engine problem is the fault of a bad or really dirty fuel injector. Take it to an Auto Zone and ask them to check the codes on your vehicle. The code will read P0304 if it's # 4 cylinder that's misfiring. We call it a dead cylinder that doesn't seem to always be dead. Because normally it just shakes a little at an idle, is smooth going up the gears, until it gets into overdrive and it will shake and vibrate like all is going to come apart. Find out which cylinder is dead and change that injector. Done.
NO WAY OUT.TRY CAN REMOVE WINDOW CONTROL SWITCH.SHAKE THE WIRES.IF THE WINDOW SWITCH BAD SHAKE WIRES TO THE SWITCH WINDOW MIGHT TRY TO GO UP.IF NOT.SWITCH IS BAD.TO GET WINDOW UP PROBABLY HAVE TO REMOVE DOOR PANEL TRY TO MANUAL GET THE WINDOW BACK UP..I TELL YOU A QUICK CHEAP FIX.GO TO SALVAGE YARD YOU CAN BUY A SWITCH FOR AT LEAST $50.00 DOLLARS. A NEW SWITCH WILL COST ABOUT $125.00
Hi I am Vortashpossibly a loose plug or the bulb housing is not secure and the cut off switch is not contacting .. loose fuse .. dry joints o loose component .. one thing is for sure keep shaking it
and your going to kill your bulb ?. During the arc on the lamp it builds up carbon deposits if they break loose they get hot in the bulb under working conditions against the glass and sometimes fracture it ?. don't shake your your unit unless you can afford to replace this at between $400 and $800 i bet that repair would be a more economic solution hope this helps Regards Vortash
