Jack Lalanne Power Juicer 250 Watts Logo
Lynda francis Posted on Mar 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My juicer isn't juicing properly it has lots of pith in the juice
When I juice fruit the juicer doesn't seem to get the juice out of the fruit very well the pulp is quite wet and I don't get much juice.
Terry
Level 3:
  • Jack Lalanne Master 11,377 Answers
  • Posted on May 09, 2018
Terry
Jack Lalanne Master
Level 3:
Answers
11377
Questions
Helped
4626814
Points
152765
4 Related Answers
Anonymous
  • 9 Answers
  • Posted on Sep 05, 2008
SOURCE: Jack Lalanna Power Juicer
Visit www.powerjuicer.com and find a replacement part.
Anonymous
  • 5 Answers
  • Posted on Nov 08, 2009
SOURCE: I HAVE A NEW JACK LALANNE POWER JUICER
The plastic top doesn't come off. Together, it's just a piece that you use to push the fruit down into the chute.
Good luck.
Anonymous
  • 356 Answers
  • Posted on Apr 04, 2010
SOURCE: Juicer is not economical in extracting juice; the pulp is juicy.
SHREDDER BLADE MAY BE DULL OR LOW RPM.
Anonymous
  • 356 Answers
SOURCE: Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
After juicing just a few fruits and vegetables the machine start jumping all over the counter and vibrating really fast.
There is no solution. These juicers do not eject the pulp and go out of balance very easily.
Don't feel bad, I've seen you tube videos where the demonstrator couldn't keep it under
control. If you are unable to master it, consider a pulp ejecting or masticating type juicer.
4answers
How to make orange juice from fresh oranges
Peel 4 medium size oranges and place in the juicer.
Juicing Tip: When juicing oranges (or any kind of citrus fruit) it is a good idea to juice the white membranes at the center of the orange. The majority of the bio-flavonoids in citrus fruits are found in the white membranes. Scrape off some of the white membranes inside the peel and include them in the juice. We don't recommend juicing the whole peel, this will produce a very sour unpleasant juice.
3helpful
Sometimes it will spin out of control the lid pops off and its scary! This seems to happen when I juice cucumbers even though I take the seeds out. Yesterday I juiced lettuce leaves, celery (2 sticks),...
DROP THE FILTERS. FRUITS AND VEGETABLES HAVE TO BE FED SLOW
AND STEADY. IF THE JUICER IS OLD THE
GAP BETWEEN BLADE AND CHUTE MAY
BE TO WIDE LETTING LARGER PIECES
THRU AND THROWING IT OUT OF
BALANCE. USING ONE FOR 19 YEARS
AND THEY ARE TRICKY.
2answers
Breville Juicer not juicing properly
MY WIFE HAS ONE AND IT'S LIKE A LOOSE CANNON. IF IT IS LEAKING FEED IT
VERY SLOWLY.
2helpful
2answers
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Acme 6001 juicer. Excessive vibration and movement during use.
usually the vibrations are caused by improper assembly ( it does not take much ) or the rate of feeding material into juicer. feed the juicer too fast and it gets out of balance.
2helpful
Stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
Top Jack Lalanne Juicers Experts
ADMIN Andrew
ADMIN Andrew
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
