Converter box turns off by itself when watching tv.
I am on antenna, and every time I watch tv my converter box turns off on its own. I don't know why it is doing that. My brother has a converter box that is hooked up to his antenna, and his converter box turns off by itself too. Is there a way to fix this problem?
Insiginia converter box turns itself off after 2-3 hours..box is hooked to an antenna
AnonymousFeb 26, 2009
My grandparents have the Insignia converter box and it is turning off by itself as well. I suspect the box is overheating. I'm going to take it back to Best Buy and try to exchange it tomorrow. My grandparents have the Insignia converter box and it is turning off by itself as well. I suspect the box is overheating. I'm going to take it back to Best Buy and try to exchange it tomorrow.
Our box has just started turning off after an hour or so. We've had it for a few weeks but only started doing this in the past couple of days. It feels like its overheating. We bought an Apex from Best Buy.Our box has just started turning off after an hour or so. We've had it for a few weeks but only started doing this in the past couple of days. It feels like its overheating. We bought an Apex from Best Buy.
AnonymousApr 01, 2009
Can set up to record program,convertor box turns off after about 5 hours.Cannot record program then.
JlHi,
Jl
insignia converter box turns TV off. This began occuring apprx 2 wks
ago after being in use for 6 months. Very irritating..insignia converter box turns TV off. This began occuring apprx 2 wks
Go to MENU then SETUP, go to SYSTEM SETTING. Scroll down to AUTO SLEEP & arrow right to OFF. Don't forget to press enter to save the setting. This solved my problem & I hope it solves your's.Go to MENU then SETUP, go to SYSTEM SETTING. Scroll down to AUTO SLEEP & arrow right to OFF. Don't forget to press enter to save the setting. This solved my problem & I hope it solves your's.
You can't post conmments that contain an email address.
Re: Converter box turns off by itself when watching tv.
Check the settings in the menu--many boxes have "power save" mode and will shut off after anywhere from 2-12 hours of inactivity. You should be able disable it or change it to a longer time.
It depends on the tv itself, all newer TVs will just need an antenna but if the tv does not have the newer digital tuner in it (you can find out by googling the tv model number) You will need a converter box.
The connection will depend on the stations in your area. Connect the antenna to the lowest RF (coaxial) connector labeled VHF/UHF if you want to watch only the low-power NTSC (analog) stations directly from your antenna. Use the Aux RF connector (upper-most RF connector) if you use the RF out from a digital (ATSC) to analog converter box and don't plan to watch the low-power stations in your area. (If you use the component video output of a converter box, ignore the RF connections.)
If you plan to watch the low-power stations and use a converter box, connect the antenna to the VHF/UHF connector. Connect a second coaxial cable to the To Converter RF connection and connect this to the Antenna In on the converter box. Take a third coaxial cable and connect this to the Antenna Out on the converter box and to the Aux RF cable input on the TV. Press the ANT button on the original remote to switch between the converter box set to channel 3 or 4 and the low-power stations. Remember to change channels with the converter box remote for the ATSC channels. Note: the converter box is used like a cable box with some scrambled channels.
so first tv is analog ?you need a second converter box if you want to be able to watch different channels at the same time on the two analogue tv'sYou could put an antenna splitter in .So could put an antenna splitter in on .antenna to feed to second analogue to digital converter box.Also depends on signal strength may need to amplify antenna signal - check tv antenna mast head amplifierthe tv signals are digital only most likely
converter output be careful check second tv has hdmi input as converter output has to match what tv can cope with.
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
If neither TV has a digital TV tuner, you will only be able to watch one channel on both TVs with one converter box. You will also need some sort of RF repeater if you want the person in the second room to change the station without moving the box. You will need a splitter/amplifier connected to the converter box TV out. (I'll assume you are using the coax out.) If you will only watch one TV at a time, then use an A/B switch on the converter box TV out.
If one of the TVs has a digital tuner, put the splitter/amplifier between the antenna and the converter box and the TV with the digital tuner.
Note: amplifier/splitters and switches do fail. If you get a "no signal" message, take out the splitter and connect the converter box directly to the antenna or one of the TVs depending on your set up.
I hope this helps.
Cindy Wells (I use an A/B switch between the antenna and the TV and converter box for feeding an old VCR/DVD recorder.)
You may have several problems.
If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals.
The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Unfortunately no, unless you get a second converter box. You're using the converter box to select channels, and it can only be on one channel at a time. With a second converter box, you might find you need a second antenna too (so you can get a signal on both channels). And you can't program your VCR to record on different channels (since it can't control the coverter box to change channels).
(This is a case of history repeating itself. When cable TV was new, and most TV's and VCR's weren't cable-ready, you needed to use the cable company's converter box. The same problems came up then too!)
Here is my setup.
1) Separate DVD player
2) Separate VCR
3) Digital to Analog Converter box
4) Analog TV
5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.
The RF-output of the converter goes into the RF-Input of the VCR
The DVD output goes into the front input jacks of the VCR
The VCR RF-output goes into the TV RF-Input
The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3. The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded. The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on. The TV is set to channel 3. Just press play on the VCR.
To Watch TV. Turn the TV and converter on. The TV is set to channel 3. Change the stations using the converter.
antenna
Jl
