Pride Jazzy Select 6 Logo
Anonymous Posted on Mar 02, 2013
After charging my wife's Jazzy Select 6, all lights come on after power up. However, when the scooter runs for just a few minutes, it drops to 4 lights on and then goes to 3 lights not too long a
I think the charger is working correctly - however, it doesn't seem like it takes very long to charge the scooter (maybe an hour or two at a time...)
  • Anonymous Jul 04, 2013
    My Jazzy Sect 6 does the same thing. Changed batteries, used a friends charger, no difference. Can't check voltage output of charger because it needs a "trigger" voltage to turn on. Old batteries and the new set of batteries check 13+ volts.
Rob Hill
Level 3:
  • Pride Master 1,480 Answers
  • Posted on Mar 02, 2013
Rob Hill
Pride Master
Level 3:
Answers
1480
Questions
0
Helped
518020
Points
3838
Hi, well that sounds like the batteries have called it a day,
If possible try another charger because sometimes the problem can be created by the charger not charging properly or the problem with the batteries being made worse by a dodgy charger.
Regards
GeWiz.
  • 6 more comments
  • Anonymous Mar 02, 2013
    I did put a volt meter on the charger and checked it and it is showing around 30 volts of charging power which I understand to be the correct voltage
  • Rob Hill
    Rob Hill Mar 02, 2013
    hi, no that's wrong , the maximum voltage should be 28.3 (MK recommended max charge voltage) , check the battery manufacturer's , the charger is damaging the batteries or shall i say damaged the batteries in question.
  • Rob Hill
    just to clarify i mean the voltage measured at the battery terminal once fully charged not the charging voltage..
  • Anonymous Mar 03, 2013
    Ok...just a little confused. It is an external charger and when I test across the terminals, it reads approx 30 volts. I have also removed both batteries after my wife had driven it approx 45 min and checked the voltages of the batteries. One read 70% and the other was at 80%. I then proceded to put the battery charger on both of them and they both charged to 100%. I check them about an hour later and the voltages for both are at about 12.7 volts I have not load tested them but they appear to be okay so far. Any other suggestions?
  • Rob Hill
    Rob Hill Mar 03, 2013
    hi, yes they are damaged, the 30 volts combined reading is the issue, now the combined battery voltages are adding up to 30 volts that is too high and over time damages the batteries.
    Just to clarify...the voltage across the terminals of the charger itself is approx 30 volts (not connected to the Jazzy itself. The voltage across the terminals of the batteries themselves is actually about 25,3 volts. I did put both of the batteries on an economy battery load tester and they both passed the test. I'm just a little frutstrated and confused as to what may be causing the batter light levels to drop so quickly on the Jazzy itself and why it only takes an hour or so at the most to charge them once the scooter has been driven...
  • Rob Hill
    if you are running the batteries down and then they taking about a hour to fully charge spells trouble, they charging too quickly so once again i say the batteries are damage internally now there are a number of factors that govern charging times , one is the amp rating of the charger, the higher, the quicker it fully charges but also the Amp /hour rating of the batteries in question, now from my experience i would the batteries need replacing.
  • Anonymous Mar 04, 2013
    The charger is a 5 amp charger
5 Related Answers
Anonymous
  • Posted on May 13, 2009
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Lee Glascock
  • 384 Answers
  • Posted on May 24, 2009
SOURCE: dead and wont move cant charge but batties are ok
sounds like a dead battery on the unit. see if you can get it replace .
oregoon
  • 175 Answers
  • Posted on Jul 11, 2009
SOURCE: I have a Rascal 600f scooter that seems 2 work
It is pretty common for the meters on the charger to either not work at all, or give an inaccurate reading. They get bounced and dropped, and they aren't that well built to begin with. Basically, just ignore the charger as long as you are getting a full charge out of it, and getting good distance with each charge.
Anonymous
  • 6 Answers
  • Posted on Sep 09, 2009
SOURCE: We purchased a Rascal 300 two months ago that
Also check the fuses.
Anonymous
  • 692 Answers
  • Posted on Mar 15, 2011
SOURCE: battery charger indicating that batteries
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
What does a flashing speed light on jazzy select 6 mean?
INFINFB2047 Jazzy Select Troubleshooting - Pride Mobility
https://www.pridemobility.com > pdf > infinfb204...
PDF troubleshooting instructions for the Jazzy Select Power Chair. ... 1 Flash. The batteries need charging. Check the battery connections. If the battery.
3 pages
Videos
https://www.google.com/search?q=flashing+speed+light+on+jazzy+select+6
Why doesn't it work?
The flash code appears to indicate your batteries need charging.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
I jhave a Jazzy Select GT power chair, I put the charger on it when the light shown red and green, when it powers up when charged the both lights will turn green, but now it will do nothing with start
Hi Gloria,
The first thing you need to do is measure the voltage at the charging socket of the Joystick (outside 2 pins). This will determine a lot of things, so I can guide you further.
Jazzy Select 6, Charge batteries. Green light comes on...run for a few seconds and goes directly to red light. Chair will continue running. One battery shows a charge of 12 volts the other 13 volts. Has...
Hi You need new batteries If you have a battery store near home or an interstate battery distributor have them get you 2 U1 batteries. Charge before use and you should be go to go for another 3 years or so Hope this helps
I have no owner manual, the scooter was my father in laws who recently died. I am having two knee replacement surgeries in the next few months. How much of a step can the scooter navigate if any at all....
I don't recommend going up or down steps without a ramp to drive on. Portable ramps are available from a number of sources on-line. The owners manual for this power chair is available for download from the following link:
http://manuals.monsterscooterparts.com/mobility/Jazzy/manual-jazzy-select-series.pdf
Hope this helps.
Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
