If you open other doors besides the driver door do the lights work? If so the door ajar switch is defective in the driver door. Also can you turn on the interior lights from the headlight switch control?
easiest check fuses for blown fuse. Inspect wiring to see if they are unplugged replace bulbs even if they look good. Bottom left of dash under steering wheel locate sunglass holder, open holder and then pull up fusebox underneath
I am assuming that when you say no alt light on dash , you mean that when you first turn key on for the bulb check it won't light. i f this is true then I would be looking at replacing the bulb first. most car's use the bulb in the dash as part of the excitment circut to get the alt to start charging.
could have the wrong bulbs in. some bulbs are single or double filament.check bulbs.if good your bulb sockets could be bad or you got grounding problems.
