I have your red popcorn maker and it has worked fine for quite a time..however, this model does not have the vented top to allow steam to escape. Please send me the top cover for the later models so that I may drill holes in top and then use new top. Phil Evans [email protected][email protected] 722 Last Arrow, Houston TX 77079 Thank you.
Steam leaking from the group when the steam function is turned on:
This is normal - as there is a spring valve which stops the steam escaping normally, however if you are not using the steam wand - steam has to escape somewhere and is vented through the group.
It will not affect the steaming - but you are better to make coffee 1st and then steam the milk.
The new Dreams have endless steam - which is great for larger groups over for dinner .. When the steam button is switched off the extra steam will vent into the water tank - new models with solenoid. https://www.bluestarcoffee.eu/ascaso-dream-pid-4272-p.asp
How do you clean this? I have one that seems to be having the same problem. In the inside of the machine the top is rusting as well as the brackets that hold the kettle. How do you clean this is this food safe the way it is? Can we repeat this was some type of Pete that would protect as well as be safe to eat popcorn?
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
If your in a hard wayter area the basket overflow valve may be need cleaning. Fill with white vinegar and run a full cycle. Rinse by running 2 or 3 cycles with clean water. You may need to repeat the vinegar cycle if the problem persists.
I think it probably is the heater core leaking.As the water eats up to boiling point small cracks will allow steam to escape. Probably smells like coolant.
That big nut is the pressure relief valve. It should normally be closed, unless the machine overheats, in which case it will vent the steam, thereby preventing an explosion.
The valve design means that it's somewhat normal for some steam to vent as the machine heats up, but once it gets close to working temperature, it should seal.
Pavoni does now have a replacement valve that avoids this problem. When your machine needs a major service, hopefully more than 5 years from now, you may decide to get the upgraded valve fitted.
Cuisinart makes fresh, crunchy, homemade popcorn fast, easy¿.and healthy! The Cuisinart Popcorn Maker pops up to 10 cups of popcorn in under 5 minutes, and lets popcorn lovers decide just how much, and what kind, of popcorn, oil and flavoring to use. Popcorn pops right into a clear plastic bowl that flips to serve, and both bowl and poping plate go into the dishwasher.
