Hi can anyone tell me what error code 997 is on avery berkel industrial floor scales
SOURCE: need manual to reset scale to weigh properly
Either do a search for that particular scale brand & model, which should take you to the company, whom should have a manual on-line or go back under search and type in "users manuals". There should be several manual websites that come up. Just don't click on the websites that require money for their manuals, when you can get them for free at other sites.
SOURCE: How do i know battery is dead
the scales may have a malfuction to it, perhaps wherever you brought it may have dropped it and put it on the shelve anyway and also you may want to see if it has a reset button that may reset it and if none of that works if you havent had it long and still have the receipt take it back to where you got it and if you dont have it just get an exchange. hope ive helped in some way, let me know and good luck!
SOURCE: New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
SOURCE: I have a set of
Below is what I copied from the manual for body fat analyzer from Terraillon. The meaning of error 2 (Err2) is included
Display In the case of:
Err0 Incorrect initialisation: begin again as
explained above.
Err1 Unstable weight: begin again.
Err2 Overload: remove weight immediately.(max weight capacity 350lbs)
Err3 Body impedance exceeds the limit
(100 ohm - 1kohm): begin again.
For certain skin types an Err3 reading
may occasionally appear. In this case
you may need to dampen your feet to
improve the contact with the electrode
Err4 Percentage of body fat above the
Err5 Percentage of body water is beyond
the range. Clean the bottom of feet
with damp cloth and step on the
scale again.
Lo Battery failure: replace it.
i repaired one that did not have batteries installed and ran on ac only the problem was in the power supply. it had a couple swollen capacitors they should be flat on top but bad when bulged out
serials H500 00 380321
Hi there. Does anyone know wich battery have I to change?
